Notes
Vote for your favorite feature requests to make them into EPIM’s roadmap
Vote for Notes features that are important to you
A colored bold line on the left following the selected note in the tree. (EPIM-980)
10
4%
Show a number of sub-items for root notes. (EPIM-2048) - DONE
6
3%
Ability to have multiple custom sorting profiles and switch between them easily. (EPIM-2511)
7
3%
Option to view and edit 2 (or more?) leafs at the same time (EPIM-2739)
15
7%
Hide sticky notes at the upper edge of the screen, leaving just a tiny horizontal line when the mouse pointer is moved out. (EPIM-452)
4
2%
Text zooming feature. (EPIM-1575)
13
6%
Display Created and Modified dates in the status bar for the selected note. (EPIM-2120)
13
6%
Disable icons just for selected notes. (EPIM-2207) - DONE
8
3%
Visual indicator that lets you instantly grasp the rough age of a note according to the indicator’s color. (EPIM-2300)
10
4%
Show attachment’s icon in Sticky notes. (EPIM-2526)
11
5%
Option to hide toolbar in notes. (EPIM-2533)
5
2%
Add font size options smaller than 8pt. (EPIM-2553) - DONE
4
2%
Make links to other exported notes (if there are any) workable for HTML export (EPIM-2609)
8
3%
Add confirmation on deleting a leaf and allow changing a leaf to a note (EPIM-2611)
6
3%
Separate "add sibling" into 2 functions: "add sibling below" and "add sibling above". (EPIM-2626)
9
4%
Ability to add horizontal separator line between note names. (EPIM-2628)
15
7%
Show rulers next to your notes. (EPIM-2636)
8
3%
Add a column to show note additional icons (read-only, private, attachment) to the right-hand side of the tree section on order to display clearer structure of notes. (EPIM-2639)
8
3%
Highlight code for the popular programming languages. (EPIM-2658)
7
3%
Choose background color for section with note trees. (EPIM-2695) - DONE
10
4%
Ability to choose a default icon. (EPIM-2713) - DONE
15
7%
"Follow Hyperlink" option when right-clicking on a link. (EPIM-2715) - DONE
5
2%
F3 hotkey to redo the last search. (EPIM-2732) - DONE
14
6%
Increase indents for tree levels for easier perception of the tree structure (EPIM-2340)
4
2%
More style modification settings like paragraph frames, list settings, etc. (EPIM-2340)
11
5%
Wrap notes names and disable horizontal scrolling in trees (tree tiles will be cut off instead of wrapping) . (EPIM-2592)
3
1%
Total votes: 229
Has thanked: 921 times
Been thanked: 533 times
Notes
If you wish to see a certain feature implemented in EssentialPIM, vote for it so that we know how "wanted" a feature is by looking at the number of votes it gets.
We didn't impose any limitation on the number of features you can vote for, although please keep in mind that our resources are limited and therefore vote only for the ones you really need.
Re: Notes
Implemented in EssentialPIM 9.6 (22-Dec-2020)
- Option to hide toolbar in notes. (EPIM-2533) //customizable toolbar
- Choose background color for section with note trees. (EPIM-2695)
- "Follow Hyperlink" option when right-clicking on a link. (EPIM-2715)
- F3 hotkey to redo the last search. (EPIM-2732)
Implemented in EssentialPIM 9.5 (03-Nov-2020)
- Ability to choose a default icon. (EPIM-2713)
- Show a number of sub-items for root notes. (EPIM-2048)
- Disable icons just for selected notes. (EPIM-2207)
TumbleDoor
Been thanked: 13 times
Re: Notes
Post by TumbleDoor »
There's lots of individual icons I'd like to hide in the notes toolbar, but I wouldn't want to hide the whole toolbar.
Is there a reason toolbar customization isn't an option to vote on?
Re: Notes
I think that's a question of broader kind of customization that will also be related to the main EPIM toolbars in each of the modules.
dirmansyah
Re: Notes
Post by dirmansyah »
"Add confirmation on deleting a leaf and allow changing a leaf to a note (EPIM-2611)"
Yes. But, I think, the confirmation is not something to be voted. A confirmation on deleting anything is a must. It is the option to disable the confirmation that should be put into the vote.
dirmansyah
Re: Notes
Should the item that has been implemented be removed from the list ?
Re: Notes
In this case voting results will be nullified.
NeRo1968
Re: Notes
Post by NeRo1968 »
Hi! I would like the integration of audio notes especially to be included in your Apps!
