Czech translation
- Has thanked: 32 times
- Been thanked: 54 times
Re: Czech translation
1.
a) "EPIM (*.epim)" you can find in File->Import (and submenu) & File->Export,
b) "Check" is related with importing the entire database and checking the database, the text is not found in the language file
- postponed,
c) The line 897 "Select parent note" additionally translated.
2. The Czech translation contained a duplicate entry, the second text was empty - fixed.
3. The lines 8752 and 6146 have been fixed.
4. Postponed.
5. Postponed.
6. The text "Width: default width Default" looks strange in Table properties->Table, "default width is poorly translated in a given context - postponed.
7. No answer.
8. Predefined response - fixed.
9. Ok, the Czech translation uses common terminology. I like this version of text much more, easier to understand.
10. The lines 6458 a 6442 "Authorization verification" - fixed and improved.
11. During translation was unconsciously canceled the assignment to line nr. 6814 - fixed, but the text was not found in the Password module.
- postponed,
4. Postponed.
5. Postponed.
7. No answer.
Jiri Humplik
http://www.epimcz.wbs.cz
- Has thanked: 1639 times
- Been thanked: 1160 times
1b. I couldn't find that word "Check" anywhere. Please attach a screenshot showing it.
As for the rest of the points - ok.
Hi, I am gradually adding the translated strings to the original version of the Czech file by J. Humplík. Not everything is translated, the e-mail environment is translated almost completely. If you try the translation and write here any errors, I will try to track them down and fix them.
edit 24.1.2023: I deleted the original version of the language file, please use the one from the following post
Second version of the file with Czech.
Internally corresponds to the English language file (order of items), all strings are translated.
I do not use the EPIM Pro version, nor all the modules and functions of the free version - therefore I cannot test the suitability of all translated items.
You can post your findings here. In Czech or English.
Druhá verze souboru s češtinou.
Vnitřně odpovídá LNG souboru v angličtině (pořadím položek), všechny řetězce jsou přeloženy.
Nepoužívám verzi EPIM Pro, ani všechny moduly a funkce bezplatné verze - proto nedokážu vyzkoušet vhodnost všech přeložených položek.
Své poznatky můžete zveřejnit zde. V češtině nebo angličtině.
- Czech.lng
- (125.39 KiB) Downloaded 435 times
DžejPý, let me know if you'd like to switch to the Pro version, will gladly forward you a key.
Thanks for the offer, I would like the Pro version if I could use it permanently, even after testing the translation.
The trial version will be enough for me to test the translation. Mainly I need to click through all the features, options and settings of EPIM...
Some strings in the contact details are not translated: middle name, title and notes (see Attachments).
The middle name is translated in the string 266, but is it the correct string?
Ok, please check you PM.
As for the fields - you'd probably need to re-create them. Or create a new DB.
