Bug: no background sync, again
Trinitylab
Has thanked: 16 times
Been thanked: 41 times
Post by Trinitylab »
EPIM Win 8.1 to Android Pie
Since a couple of weeks (3?) there is no background syncing at all.
I have to do it manually, and obviously with a huge pain (full of error messages on Android, like lack of connection and many others).
Re: Bug: no background sync, again
So maybe background sync is not happening as there's lots of connection errors? What do they specifically say?
Trinitylab
Errors typically are when I want to sync manually, "No connection" and so on.
Then I have to "initiate" sync from PC, which is impossible, but it appears that when I do it, the manual sync is ongoing, while 30 sec. ago on Android it said "No connection" or something, I do not remember now the exact message.
Trinitylab
Now on PC:
access violation at address 014396FE in module EssentialPIM.exe. Read of address 00000008.
Please note also, that there is no chance to copy and paste this message. Either screensave or manual typing. You could have made it easier.
You cannot initiate synchronization from the PC as it acts as a server and waits for connection from the Android counterpart app. Please try to remove and then re-create the synchronization.
Trinitylab
I did, and the above error still appears.
I believe this is in regard to background sync, because it pops up in the morning when I start EPIM, after some time, seconds or minutes.
I think PC wants to connect with Android to sync in background, and cannot.
PC version cannot and will not try to connect. That's Android EPIM which always initiates connection.
As for the error message, please hit the Send button and forward it to us, will analyze and fix. Thanks.
Michel
Post by Michel »
WINDOWS 7 PRO 64
EPIM Pro 8.53.1
I have the same bug for many days now:
access violation at address 0143A2DA in module 'EssentialPIM.exe'. Read of address 00000008
this message appears on my PC when initiating sync from my Android Phone
Already done:
- removed and then re-created the synchronization
- uninstalled/reinstalled epim android app
- uninstalled/reinstalled EPIM Pro 8.53.1
No improuvment
Regards
Michel
PS: see attached EPIMSyncErrorLog from epim android app
EPIMSyncErrorLog_20190704045954.txt
(924 Bytes) Downloaded 94 times
Trinitylab
Still the same.
Until I do a manual sync, no sync in background. And the error: access violation and so on.
Michel, Trinitylab forward me synchronization log files from Windows EPIM, as well please. They can be found here: Tools->Options->Synchronization, Browse... and the filenames should start with "AndroidSync". Thanks!
Trinitylab
No sync at all, 8.54.2, either manual or in background. Manual - cannot find PC, socket and port in use.
What do you mean by that: "socket and port in use"?
Trinitylab
The message on desktop EPIM.
Though yesterday I was able to sync manually, doing nothing different way.
That error indicates you likely had more than a single copy of EPIM opened at a time.
Trinitylab
Yes, we use three different DBs daily. But only one of them syncs with Android. Two syncs with Google.
