BUG - Private notes title visible
Locked
Rick12
Been thanked: 7 times
Post by Rick12 »
Private notes title are visible in the tree of the dialog Insert Hyperlink (for Related Items for example)
Version of EPIM: 8.54.1 Pro Portable
Windows: 10 64 bits
Rick12
Re: BUG - Private notes title visible
Post by Rick12 »
I tested the note module, and the bug is still present with EPIM 8.54.3 Pro Portable.
EssentialPIM Pro Portable 9 Beta 1
Windows 10 64bits
have you hidden Private items via View-> Show Private items?
On my tests, when they are hidden in main view, they are also hidden in the linking dialog. If you can still reproduce the issue, please also include the screenshot, demonstrating same private items are not visible in main view (i.e. hidden using View-> Show Private items)
Rick12
Post by Rick12 »
Yes. I have used the shortcut Ctrl+L to hide private items.
Here is another screenshot of the problem.
In the linking dialog, the private item title appear in the tree (but not in the items panel) as shown in the screenshot.
Here is another screenshot showing a private tree showing in the linking dialog.
Windows 10 64bits
Locked
