Module Password, Doubleclick-copied URL contains HTML tags
- Has thanked: 4 times
- Been thanked: 15 times
Window 7 64bit Pro
Essential Pim 8.54.3
Steps to reproduce:
1. Create new Password entry.
2. Enter the URL (manually or CTRL-V'd)
3. Save new password entry
4. Double click on the "URL" label of the password entry
Expected result:
Clipboard should contain
Current result:
Clipboard contains
This is most annoying when pasting into a browser's address bar or any other non-html processing target, e.g. text editor.
(I know I can click on the URL in the list and it opens in Standard Browser, but I do not always wish to use the standard browser)
Note: URLs pasted into password entries with <= 8.15 do not show this behaviour (I jumped from 8.15 to 8.54)
Steps to reproduce:
Expected result:
Code: Select all
https://www.essentialpim.com/forum/
Clipboard contains
Code: Select all
<a href="https://www.essentialpim.com/forum/">https://www.essentialpim.com/forum/</a>
Re: Module Password, Doubleclick-copied URL contains HTML tags
Any news on this? It's really bothering: I need to enter 'AAA https:// ...' in the field whenever I make a new entry as a workaround to prevent this.
Thank you, issue noted, will fix in one of the next updates.
