Version 8.6 Portable
Nothingness
Been thanked: 4 times
Post by Nothingness »
What happened to the zip file for the portable version?
Bring it bacK! I use the portable version, and they're always in zip format, or they're like on Portable Files website, an exe that downloads the necessary files over the internet. A single installer makes sense for regular version, NOT the portable version. Who is the idiot who came up with that? The portable version is NOT portable anymore!!!
Windows 7 Home Premium 64 bits - Best OS ever - Have a lifetime licence
Re: Version 8.6 Portable
It actually is. Once you run the executable and choose the Portable version for installation, it will be extracted into the folder of your choice same way as if you'd do this manually yourself.
Plus, the new system allows automatic updates for the Portable version. No need to do that manually anymore.
knegsel
Has thanked: 33 times
Been thanked: 8 times
Post by knegsel »
Its great to automatic update with portable version with the new option
lacn
Has thanked: 5 times
Been thanked: 63 times
Post by lacn »
The problem with this new installer is that the portable version is no longer fully portable.
Actually, the folder Dict is no more in the application folder and is stored in "User\AppData\Roaming\EssentialPIM Portable\Dict".
For fully portability you have to fix that problem.
Will fix ASAP, thanks for the info!
Fixed in the 8.6.1 version.
Reason: New version release
lacn
Post by lacn »
Now everything is fine! :)
mvisconte
Beta Team
Has thanked: 50 times
Been thanked: 15 times
Post by mvisconte »
admin wrote: Tue Oct 15, 2019 6:47 pm Once you run the executable and choose the Portable version for installation, ...
Plus, the new system allows automatic updates ...
Max,
I don't know if anyone else has this issue, but some of us don't have full admin perms on our machines. Permissions get locked down as part of standard security measures. Auto-updates are also frowned upon and are supposed to be strictly controlled.
I don't know wx this is going to halt me.
I did the equivalent of unpacking and extracting the .exe
I'm testing the operation as if it's portable, now.
I will see if there is a problem running the installer in the next week or so.
Let us know if you find any issues with the current system, will make adjustments to it, if needed. Thanks!
nath84
Has thanked: 25 times
Been thanked: 11 times
Post by nath84 »
admin wrote: Tue Oct 15, 2019 6:47 pm (...)
Is that "vérifier la mise à jour automatique" in" options" and "général" ?
automatic updates is excellente :D :D :D , I hope it will work well !
thanks for your answer and thanks to make Epim getting better and better, I've been using EPIM for 10 years and I would not change for another one :D
best regards
Nathalie
Yes, that the correct option that you mention. You should be able to experience auto-update of the Portable Pro version to the 8.61 one in the coming days as update is rolling out in stages now.
nath84
Post by nath84 »
I had the same problem than Nothingness with the 8.6 updating... No zip file.
I Just waited for the next update and It is OK now, I work with epim 8.6.1 😀
Waiting to expérience the next auto-updating 😉
Thanks for all
Nathalie
Let us know how it went once you get it :)
nath84
Post by nath84 »
With pleasure !
nath84
Post by nath84 »
complete success for the new auto-updating :-D
long life to EPIM and team !!!
have a good day !
Nathalie
mvisconte
Beta Team
Post by mvisconte »
nath84 wrote: Sat Nov 09, 2019 5:48 pm 👍🏽👍🏽👍🏽
For those who cannot use the auto-update, you may be able to update manually by extracting the files yourself:
1. Going to the Get EPIM web page: https://www.essentialpim.com/get-epim
2. Downloading the .exe
3. Opening it as an archive, with WinZip, 7Zip, etc.
To open the downloaded EXE as an archive:
For 7Zip, start the 7Zip FileManager,
Navigate to the directory containing the .exe
Select the .exe, right click, and from the pop-up menu, Open Inside
(instead optionally, you can select 7-zip / Open Archive).
This will show two folders:
$TEMP
$PLUGINSDIR
Double-click / navigate into the $TEMP directory.
There will be two .exe's:
EssentialPIMPronn.exe
EssentialPIMProPortnn.exe
Right click on whichever is desired, and select Open Inside.
You will see the contents of the executable, containing 20 r so objects, including executables, dlls, subfolders, etc.
You may copy/extract from these into your own file system directories.
This is recommended only if you are comfortable with manipulating your own files.
