Reminder Ringtone
Has thanked: 794 times
Been thanked: 426 times
Re: Reminder Ringtone
Okay, let's see if we're trying to correctly reproduce the problem, assuming you have a new clean installation of AEPIM and a new WinEPIM database file.
1. You go to AEPIM settings, click on the Reminder and Ringtone option and choose one of the system sounds for "Sound"
2. Create a new test event with a reminder and wait till the reminder comes up. As I understand you're going to hear the sound you set up in the previous step
3. Create another test event with a reminder to be fired up in couple of minutes in AEPIM. Meanwhile setup and perform synchronization with WinEPIM. What happens now when the reminder sounds - will you hear the chosen in the first step sound on Android? If yes, see the next step
4. Create a test event in WinEPIM with a reminder to be sounded in couple of minutes. Synchronize with AEPIM. Which sound is going to be used now on Android when the reminder comes up?
markdate
Post by markdate »
1 Yes
2 Yes and I hear the chosen sound
3 After syncing I can hear the default system sound for notification
4 The same as in 3
Thanks, I think this might be related to the ASUS ROM as it works as expected on our test devices. Will try to get hold on an ASUS device to check it out..
