Consolidated View or Search of All Task Tabs?
On the Windows and Android Task Modules, I can search for tasks by tags or other fields within each tabs. Is there a way to do one search to cover all tabs so I don't have to repeat the search for each tab?
Re: (SOLVED) Consolidated View or Search of All Task Tabs?
I was in the Tree or Plain mode so only saw the tabs. I saw the Consolidated option on the side bar --- did exactly what I needed.
Enjoying the new-to-me features in the current EPIM.
