EssentialPIM 9.0 Release Candidate
MetalDrop
Been thanked: 189 times
Re: EssentialPIM 9.0 Release Candidate
Post by MetalDrop »
Find & replace appears to be broken:
knegsel
Has thanked: 33 times
Been thanked: 8 times
Post by knegsel »
why is the "read-only" circle not red in 9.0 RC2 in a light theme
Keldi
Has thanked: 26 times
Been thanked: 92 times
Post by Keldi »
In the Anchors window Delete is right between the Add and 'Go to', and there is no way to undo the deletion of an anchor if you click on it accidentally. Maybe a switch of places for the Delete and 'Copy as Link'?
MetalDrop, unable to reproduce the issue with Alt+Click. Please check it out on a new database. As for the Find & replace issue - confirm, will fix.
knegsel, will improve, thanks for noticing it.
Keldi, good idea! Will do.
MetalDrop
Post by MetalDrop »
admin wrote: Sat May 16, 2020 12:14 pm MetalDrop, unable to reproduce the issue with Alt+Click.
Yes, it did happen with a new database... turns out it was a rather funny coincidental dual alt key failure on my keyboard.
Keldi
Post by Keldi »
Issues with bullet/ordered lists in Appointments/Tasks:
1.
Create an appointment and type something like this into it:
One
Two
Three
Save the appointment with OK button (before saving the lists work just fine).
Open it again, select the "Two" and apply bullet list. The bullet will be near the first line instead of the selected text.
The same with ordered lists.
If you type something else below, for newly typed text the lists will work. But if you type something, save the appointment, open again - for this text too a bullet will be put near the first line of text in the appointment.
(an animated gif attached)
2.
An extra empty line appears before the list after you save the appointment.
Before saving:
After opening again the appointment that was saved:
Keldi
Post by Keldi »
Add a table into a note and start typing several lines of text.
Sometimes an error happens after a couple of Enter's, sometimes it takes more than 20 lines. I haven't figured out what exactly causes it.
An animated gif in the Attachments.
Code: Select all
List index out of bounds (4)
Class: TRVItemList.
Exception log with detailed tech info. Generated on 17.05.2020 23:38.
 Application title: temp.4F8DE8FA.epim - EssentialPIM Pro Portable
 Application file: D:\EssentialPIMProPort90RC2\EssentialPIM.exe
 Application: EssentialPIM Pro Portable 9.0 RC2  15.05.2020
Exception class: EListError
Exception message: List index out of bounds (4)
Class: TRVItemList.
Exception address: 004BB186
Main thread ID = 1356
Exception thread ID = 1356
Object Logs:
1334774662  AppRestore OK
1333911134  AppMinimize OK
1333857969  SetViewMode OK
1333857813  SetViewMode 3
1333856955  DBOpen OK
1333856019  SetViewMode OK
1333855863  SetViewMode 0
1333855707  DBOpen
1333854833  DBClose OK
1333854755  DBSave OK
1333854740  DBSave
1333854677  DBClose
1332884195  AppRestore OK
1332081835  AppMinimize OK
1332080759  AppRestore OK
1334949726  NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334949212  TableParamDialog OKBtn
1334948712  TableParamDialog GroupBox1 ColCountEd
1334928931  NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit
1334927403  NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334925889  ExceptionDialog OkBtn
1334923347  NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334921287  ExceptionDialog OkBtn
1334920960  NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334919291  ExceptionDialog OkBtn
System   : Windows 7 Home Edition, Version: 6.1, Build: 1DB1, "Service Pack 1"
Memory: 8192; free 1710
Display  : 1920x1080 pixels, 32 bpp, 96 PPI
PrevExceptions:
1333465236  List index out of bounds (4)
Class: TRVItemList
1333524018  List index out of bounds (5)
Class: TRVItemList
1333526857  List index out of bounds (5)
Class: TRVItemList
1333531630  List index out of bounds (5)
Class: TRVItemList
1333533456  List index out of bounds (5)
Class: TRVItemList
1333537871  List index out of bounds (3)
Class: TRVItemList
1333539259  List index out of bounds (5)
Class: TRVItemList
1333542925  List index out of bounds (5)
Class: TRVItemList
1333545577  List index out of bounds (5)
Class: TRVItemList
1333639568  List index out of bounds (2)
Class: TRVItemList
1333644684  List index out of bounds (5)
Class: TRVItemList
1333676867  List index out of bounds (1)
Class: TRVItemList
1333678287  List index out of bounds (1)
Class: TRVItemList
1333681766  List index out of bounds (1)
Class: TRVItemList
1333744931  List index out of bounds (5)
Class: TRVItemList
1333746927  List index out of bounds (19)
Class: TRVItemList
1333750281  List index out of bounds (19)
Class: TRVItemList
1333754384  List index out of bounds (19)
Class: TRVItemList
1333888561  List index out of bounds (4)
Class: TRVItemList
1333893444  List index out of bounds (4)
Class: TRVItemList
1334038025  List index out of bounds (7)
Class: TRVItemList
1334041551  List index out of bounds (6)
Class: TRVItemList
1334167350  List index out of bounds (3)
Class: TRVItemList
1334169409  List index out of bounds (1)
Class: TRVItemList
1334769888  List index out of bounds (1)
Class: TRVItemList
1334916997  List index out of bounds (5)
Class: TRVItemList
1334918604  List index out of bounds (4)
Class: TRVItemList
1334920960  List index out of bounds (3)
Class: TRVItemList
1334923315  List index out of bounds (5)
Class: TRVItemList
1334927371  List index out of bounds (6)
Class: TRVItemList
Updates: 1
Last update: 16.05.2020
MetalDrop, thanks for the update and hope your keyboard is ok now :)
Keldi, confirm all the three issues mentioned, will fix, thanks!
henacynflin
Has thanked: 12 times
Been thanked: 5 times
Post by henacynflin »
When you do an advanced search in RC2 the note content field is empty on both the list and the output from 'print list'
henacynflin
On 9.0 RC2
As with the advanced search when you look on the 'Related items' tab of the contact the data is empty under the 'Note Content' heading
Cheers
There's no such field in the search results.
henacynflin
There is a "note content" field (as shown in the screensht attached). However, now it is working and populated with data !!
henacynflin
Sorry here, hopefully, is the screenshot Image
https://1drv.ms/u/s!AhZYHFS9LhEthYRfsl2RE4df6ETW2g
Keldi
Post by Keldi »
There are lot of different 'notes' in Advanced search. I don't have any issues with them though.
But there is double Notes in customisation settings for appointments/tasks and so on (doesn't seem to cause any problems, I can choose either one and it works)
henacynflin, sorry, I meant there was no "Note content" field for contacts, this field is for notes. For contacts it should be "Note" field.
Keldi, thanks, confirm this minor issue, will improve.
Locked
