EssentialPIM 9.0 Release Candidate
Re: EssentialPIM 9.0 Release Candidate
Find & replace appears to be broken:
- Has thanked: 26 times
- Been thanked: 92 times
In the Anchors window Delete is right between the Add and 'Go to', and there is no way to undo the deletion of an anchor if you click on it accidentally. Maybe a switch of places for the Delete and 'Copy as Link'?
MetalDrop, unable to reproduce the issue with Alt+Click. Please check it out on a new database. As for the Find & replace issue - confirm, will fix.
knegsel, will improve, thanks for noticing it.
Keldi, good idea! Will do.
Yes, it did happen with a new database... turns out it was a rather funny coincidental dual alt key failure on my keyboard.
Issues with bullet/ordered lists in Appointments/Tasks:
1.
Create an appointment and type something like this into it:
One
Two
Three
Save the appointment with OK button (before saving the lists work just fine).
Open it again, select the "Two" and apply bullet list. The bullet will be near the first line instead of the selected text.
The same with ordered lists.
If you type something else below, for newly typed text the lists will work. But if you type something, save the appointment, open again - for this text too a bullet will be put near the first line of text in the appointment.
(an animated gif attached)
2.
An extra empty line appears before the list after you save the appointment.
Before saving: After opening again the appointment that was saved:
1.
One
Two
Three
2.
Add a table into a note and start typing several lines of text.
Sometimes an error happens after a couple of Enter's, sometimes it takes more than 20 lines. I haven't figured out what exactly causes it.
An animated gif in the Attachments.
Code: Select all
List index out of bounds (4)
Class: TRVItemList.
Exception log with detailed tech info. Generated on 17.05.2020 23:38.
Application title: temp.4F8DE8FA.epim - EssentialPIM Pro Portable
Application file: D:\EssentialPIMProPort90RC2\EssentialPIM.exe
Application: EssentialPIM Pro Portable 9.0 RC2 15.05.2020
Exception class: EListError
Exception message: List index out of bounds (4)
Class: TRVItemList.
Exception address: 004BB186
Main thread ID = 1356
Exception thread ID = 1356
Object Logs:
1334774662 AppRestore OK
1333911134 AppMinimize OK
1333857969 SetViewMode OK
1333857813 SetViewMode 3
1333856955 DBOpen OK
1333856019 SetViewMode OK
1333855863 SetViewMode 0
1333855707 DBOpen
1333854833 DBClose OK
1333854755 DBSave OK
1333854740 DBSave
1333854677 DBClose
1332884195 AppRestore OK
1332081835 AppMinimize OK
1332080759 AppRestore OK
1334949726 NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334949212 TableParamDialog OKBtn
1334948712 TableParamDialog GroupBox1 ColCountEd
1334928931 NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit
1334927403 NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334925889 ExceptionDialog OkBtn
1334923347 NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334921287 ExceptionDialog OkBtn
1334920960 NoteEditForm PageControl1 TextTS RichEditFrame1 TabsTC RichViewEdit TRVTableInplaceEdit
1334919291 ExceptionDialog OkBtn
System : Windows 7 Home Edition, Version: 6.1, Build: 1DB1, "Service Pack 1"
Memory: 8192; free 1710
PrevExceptions:
1333465236 List index out of bounds (4)
Class: TRVItemList
1333524018 List index out of bounds (5)
Class: TRVItemList
1333526857 List index out of bounds (5)
Class: TRVItemList
1333531630 List index out of bounds (5)
Class: TRVItemList
1333533456 List index out of bounds (5)
Class: TRVItemList
1333537871 List index out of bounds (3)
Class: TRVItemList
1333539259 List index out of bounds (5)
Class: TRVItemList
1333542925 List index out of bounds (5)
Class: TRVItemList
1333545577 List index out of bounds (5)
Class: TRVItemList
1333639568 List index out of bounds (2)
Class: TRVItemList
1333644684 List index out of bounds (5)
Class: TRVItemList
1333676867 List index out of bounds (1)
Class: TRVItemList
1333678287 List index out of bounds (1)
Class: TRVItemList
1333681766 List index out of bounds (1)
Class: TRVItemList
1333744931 List index out of bounds (5)
Class: TRVItemList
1333746927 List index out of bounds (19)
Class: TRVItemList
1333750281 List index out of bounds (19)
Class: TRVItemList
1333754384 List index out of bounds (19)
Class: TRVItemList
1333888561 List index out of bounds (4)
Class: TRVItemList
1333893444 List index out of bounds (4)
Class: TRVItemList
1334038025 List index out of bounds (7)
Class: TRVItemList
1334041551 List index out of bounds (6)
Class: TRVItemList
1334167350 List index out of bounds (3)
Class: TRVItemList
1334169409 List index out of bounds (1)
Class: TRVItemList
1334769888 List index out of bounds (1)
Class: TRVItemList
1334916997 List index out of bounds (5)
Class: TRVItemList
1334918604 List index out of bounds (4)
Class: TRVItemList
1334920960 List index out of bounds (3)
Class: TRVItemList
1334923315 List index out of bounds (5)
Class: TRVItemList
1334927371 List index out of bounds (6)
Class: TRVItemList
Updates: 1
Last update: 16.05.2020
MetalDrop, thanks for the update and hope your keyboard is ok now
Keldi, confirm all the three issues mentioned, will fix, thanks!
- Has thanked: 12 times
- Been thanked: 5 times
When you do an advanced search in RC2 the note content field is empty on both the list and the output from 'print list'
On 9.0 RC2
As with the advanced search when you look on the 'Related items' tab of the contact the data is empty under the 'Note Content' heading
Cheers
Cheers
There's no such field in the search results.
There is a "note content" field (as shown in the screensht attached). However, now it is working and populated with data !!
There are lot of different 'notes' in Advanced search. I don't have any issues with them though.
But there is double Notes in customisation settings for appointments/tasks and so on (doesn't seem to cause any problems, I can choose either one and it works)
henacynflin, sorry, I meant there was no "Note content" field for contacts, this field is for notes. For contacts it should be "Note" field.
Keldi, thanks, confirm this minor issue, will improve.
