EssentialPim 9.1
EssentialPim 9.1
I just downloaded and installed today's new version. And, just like 9.0 I cannot change the background color, so I will be deleting 9.1 and going back to 8.66.
Re: EssentialPim 9.1
You could change background-color in notes- just as decribed on the history page. Perhaps one could be dissapointed (I am- a little), because this works only for ALL notes but not for single notes- but it works.
I want the background color in my emails; and was told this would be fixed in "next upgrade" but not yet.
You are right, in emails it is not working..... I would not have noted it, because I do not use background-color in emails. But yes, this is a bug!
In 9.1, I noticed that if I drag an appointment with the mouse, the set reminder disappears (see attachment)
Thank you
Thank you
- reminder issue.pdf
- (164.12 KiB) Downloaded 124 times
- Has thanked: 1418 times
We aren't able to reproduce this, unfortunately. Could you please check the 9.1.1 version out, will there be the same problem?
I installed version 9.1.1 but I have the same problem.(see attachment). Any suggestions?
Thank you
Thank you
- VID_20200704_153232053.avi
- (541.04 KiB) Downloaded 132 times
Please create a new test database file and check if the problem is still there. If it is, please forward me that test database via PM. Thanks!
Hello, I just downloaded 9.1.1 and in a new email the background color still does not work. So I have un-installed 9.1.1 and resumed using 8.661 which works just fine.
We're aware of the issue, it will be fixed in the next update. Thanks!
