EssentialPim 9.1
drrwilliams
EssentialPim 9.1
Post by drrwilliams »
I just downloaded and installed today's new version. And, just like 9.0 I cannot change the background color, so I will be deleting 9.1 and going back to 8.66.
a8907433
Been thanked: 170 times
Re: EssentialPim 9.1
Post by a8907433 »
You could change background-color in notes- just as decribed on the history page. Perhaps one could be dissapointed (I am- a little), because this works only for ALL notes but not for single notes- but it works.
drrwilliams
I want the background color in my emails; and was told this would be fixed in "next upgrade" but not yet.
a8907433
Post by a8907433 »
You are right, in emails it is not working..... I would not have noted it, because I do not use background-color in emails. But yes, this is a bug!
That's noted, we will fix the bug.
PesceDog
Post by PesceDog »
In 9.1, I noticed that if I drag an appointment with the mouse, the set reminder disappears (see attachment)
Thank you
reminder issue.pdf
(164.12 KiB) Downloaded 123 times
We aren't able to reproduce this, unfortunately. Could you please check the 9.1.1 version out, will there be the same problem?
PesceDog
Post by PesceDog »
I installed version 9.1.1 but I have the same problem.(see attachment). Any suggestions?
Thank you
VID_20200704_153232053.avi
(541.04 KiB) Downloaded 132 times
Please create a new test database file and check if the problem is still there. If it is, please forward me that test database via PM. Thanks!
drrwilliams
Hello, I just downloaded 9.1.1 and in a new email the background color still does not work. So I have un-installed 9.1.1 and resumed using 8.661 which works just fine.
We're aware of the issue, it will be fixed in the next update. Thanks!
