Aunts and Uncles
henacynflin
Has thanked: 4 times
Aunts and Uncles
Post by henacynflin »
Hi All,
can anyone help. I want to move a note onto the leaf of another note. If I drag it onto the other note it makes it a child. I can't use the arrows on the top bar as they don't move it from the root to become a leaf. Is there a way to do this without cutting all the content of a note and pasting it into a blank new leaf ?
Cheers
Alan
Has thanked: 798 times
Been thanked: 429 times
Re: Aunts and Uncles
You can move (drag&drop) a leaf from one note to another note. Hope that's what you were looking for. Thanks!
MetalDrop
Been thanked: 143 times
Post by MetalDrop »
Try Dragging and dropping the leaf tab onto the other note.
Windows 7 64-bit US-ENG & Windows 10 64-bit US-ENG, Intel i7 7700k, 32GB DDR4, Nvidia & AMD Ryzen 2600 16GB DDR4 Nvidia 1080ti
[I'm helpful and often reply to questions, please note however I am just a fellow user and not staff.]
henacynflin
That works many thanks, I was being blind to the obvious :-<
