sync app android-google calendar
PesceDog
Post by PesceDog »
I use EPIM portable pro for windows that syncs perfectly with google calendar. I tryed to install App Android but it don't correctly sync whit google calendar: only categories are sync, the events aren't.
I tryied to disinstall re-install app, disable synchronization and then re-enable but problem persist.
Thanks in advance for any suggestions
Moto G6 plus vers. Android 9
EPIM android 5.7.3
EPIM windows Pro portable 9.1.1
Has thanked: 794 times
Been thanked: 426 times
Re: sync app android-google calendar
Thanks for the report, I think we know the reason for that. It will be fixed in the next update, which us due in couple of days. Thanks!
PesceDog
Post by PesceDog »
Now app syncs fine! Thanks!
