"Go to Item" in the context menu for Calendar -> Table view
jimbeam23c
Post by jimbeam23c »
I just got v9.5 of EssentialPIM, and just saw this new feature:
-> "Go to Item" option in the context menu for appointments and tasks in Today.
This "Go to Item" option needs to be present in the context menu for Calendar -> Table view.
EssentialPIM Portable 11.0.4 (Windows)
EsentialPIM 6.0.2 (Android)
Windows 11 Pro (x64)
Motorola G10
Android 11
Has thanked: 1616 times
Been thanked: 1135 times
Re: "Go to Item" in the context menu for Calendar -> Table view
Which calendar view would you expect to be opened in this case, the Day one?
jimbeam23c
admin wrote: Wed Nov 04, 2020 8:08 am Which calendar view would you expect to be opened in this case, the Day one?
For me, I'd like it to be the Week view.
But it'd be even better if the user could specify which view they'd like to open when they use the "Go to Item" in the context menu.
I just tested using the "Go to Item" option in the context menu for appointments and tasks in Today and it works as it would be expected.
What I mean is whatever the last view of the calendar was viewed, that is the view that is opened.
For example, if I use the monthly view and then go to "Go to Item" option in the context menu for appointments and tasks in Today, it opens in monthly view.
if I last used the week view, it opens up in week view.
This is perfect behaviour already and doesn't really need any user options as I mentioned earlier.
Motorola G10
Android 11
Got it, thanks! Will see if we are able to include this feature in the next update already.
jimbeam23c
I see that there was a 9.5.2 update that said that the this feature has now been implemented.
However, when I just downloaded and tested it, there was still NO such option is Calendar table view.
See screenshots as proof.
Version: https://imgur.com/o4IzbIr
Today view: https://imgur.com/5FGgzcN
Calendar table view: https://imgur.com/Q6UsWIC
Motorola G10
Android 11
The feature shouldn't have been added in 9.5.2.
jimbeam23c
Oh I see.
Could you please link to the changelog for 9.5.2?
Motorola G10
Android 11
  • Fixed several minor issues
jimbeam23c
admin wrote: Thu Nov 12, 2020 8:44 am
More details would have been good.
:-P
Motorola G10
Android 11
These are so minor you wouldn't even notice them :)
jimbeam23c
admin wrote: Thu Nov 12, 2020 3:28 pm These are so minor you wouldn't even notice them :)
Well, it v9.5.2 came just after a day or two after v9.5.1, so how minor can the changes be to issue another update so soon?
:twisted:
Motorola G10
Android 11
If you didn't notice any inconsistencies with the previous 9.5.1 version, the fixes wouldn't tell you much.
jimbeam23c
admin wrote: Fri Nov 13, 2020 3:03 pm If you didn't notice any inconsistencies with the previous 9.5.1 version, the fixes wouldn't tell you much.
Fair enough....
Motorola G10
Android 11
