An event that repeats once every two weeks, if i edit but are not gone, than choose the cancel command and then the back arrow (bottom), the application will enter the event every day.
Another event that was on the original day is deleted.
I only looked at the rule in the custom repeat menu.
Opening the event for editing (again) in the same way and exiting without modification will delete the event too.
(My phone is Sony Xperia 1, Android 9, AEPIM v5.7.4.)
Exit without saving will not work, the application will overwrite and delete.
- Has thanked: 904 times
- Been thanked: 520 times
Re: Exit without saving will not work, the application will overwrite and delete.
I'm not sure we're able to reproduce the problem. Please record a small video indicating the issue.
I record a small video, but i can't upload here.
Nothing is posed at the moment to the attachments section.
Am I not doing something right?
An error occurred: "File too large"
File size is: 8,64 MB
What is the file size limit?
I uploaded the video to this location:
https://data.hu/get/12659867/20201106_140815.mp4
Direct link: http://ddlp8.data.hu/get/fc4d72ce0efc70 ... 140815.mp4
Thank you, reproduced, will be fixed in the next version.
This is good news.
This is good news.
Is it possible to have the custom repeat also appear if we look at the details of the entry?
No need to open editing for that.
(The normal repetitions are displayed.)
It would also be useful to save only the check mark (save button)!
Do not save on back button(s) or at exit, close or collapse.
This would be good for the all modules as well.
Thank you.
Thank you.
Will try to implement that, as well.
