Does anyone have experience with running several copeis of EPIM on a LAN? Is it possible to create a Todo item fore someone on your machine and have it appear in their list when assigned to them?
Just curios as to whether this is possible and what your experience with it might be
Thanks in advance
EPM on a LAN
- rgrun1
- Has thanked: 6 times
- Been thanked: 3 times
Re: EPM on a LAN
Thanks for the reply. I may install the trial and see if it fits what I am trying to do.
Again, thanks
Again, thanks
Rick
EPIM 9.6
Windows 10 Pro
Rick
EPIM 9.6
Windows 10 Pro
- Has thanked: 906 times
- Been thanked: 522 times
Re: EPM on a LAN
rgrun1, let us know if you'd like to test several concurrent connections to the database, will forward you a special key.
- rgrun1
Re: EPM on a LAN
Thanks for the generous offer. I will contact you off list
Rick
EPIM 9.6
Windows 10 Pro
Rick
EPIM 9.6
Windows 10 Pro
