How To Import .csv File as Child Task
CHB
Post by CHB »
I am trying to import a .CSV delimited file into EssentialPIM PRO as a child task. My steps are as follows:
File > Import > Tasks > Comma Separated Values (*.csv)... (then follow the prompts).
The issue is that the records get imported as Root Tasks, but I want to import them as Child Tasks instead. Is there a way to do that (other than by manually drag/dropping dozens of records from root to child after the import is completed)?
As always, thanks in advance.
Has thanked: 1616 times
Been thanked: 1134 times
Re: How To Import .csv File as Child Task
There's currently no way, only the one you described - select tasks you need to move and then drag&drop them into the desired position.
CHB
Post by CHB »
Ok. Thanks for the prompt reply. All the best.
