how can I permanently turn off the "how do you like the app" message?
It keeps bugging me over and over again ; )
how to turn off "how do you like the app"?
- Has thanked: 1412 times
Re: how to turn off "how do you like the app"?
You can rate it once (any of the options) and the message should go away permanently.
- Has thanked: 41 times
Ok, I get that!
I don't appreciate being "forced" to rate anything though. Especially for a paid app.
I've seen people giving 1* ratings just for that reason.
Normally if you just skip the message it shouldn't appear and bother you too often. Will check out the algorithms.
I understand the reason for developers to implement theses rating reminders.
How about adding a "never rate" option after the third or fifth popup. I guess that could make everyone happy ; )
Yep, that could also be an option, will make improvements in that regard.
