Higher scrolling speed
Tester
Has thanked: 17 times
Been thanked: 8 times
Re: Higher scrolling speed
Post by Tester »
admin wrote: Sun Oct 24, 2021 10:17 am Unable to confirm this. Works fine on 9.10.7.
Yes, you are right. The fault is on my computer. I use the software "KatMouse" (http://ehiti.de/katmouse/) for determining the scrolling speed in other programs (not for EPIM) and this affects the scrolling speed respectively scrolling possibility in general. When disabling "KatMouse", all works fine.
Sorry for the false alarm. :oops:
