Notes from EPIM onto iPhone/iPad
Haldex
Has thanked: 25 times
Been thanked: 5 times
Post by Haldex »
What is the easiest way to get the notes from EPIM onto my iPhone or iPad, BUT without using Google services?
Re: Notes from EPIM onto iPhone/iPad
Direct synchronization of notes is not yet supported, unfortunately.
Haldex
Post by Haldex »
If I create a synchronisation in EPIM via Office 365 / Outlook.com, where will the notes, created in EPIM, be synchronised from EPIM to ????
They're going to be synced with OneDrive.
Haldex
Post by Haldex »
I tried directly from OneDrive on IOS into an iOS app. But the problem is that only one copy can be edited and saved on OneDrive. So changing notes is not possible without an additional file copy.
This is very sad that iOS users are left out in the cold with EPIM notes!
Google would be an alternative, as has been written. But if you don't want to make more personal information accessible to these Big Tech, this is no way to go with sensitive data.
So it would be urgent to make the notes available natively for iOS users as well, preferably in an iOS app.
By the way, the latest version of EPIM on WIN 10 runs very well.
johncesta
Been thanked: 10 times
Post by johncesta »
Yes, the notes on epim are fantastic. However the fact that they go nowhere is a drag and makes it annoying to use.
John Cesta
Knights of Columbus
Haldex
Post by Haldex »
Any news for EPIM 10, Notes and iPhone?
johncesta
Post by johncesta »
Every sync for notes is unbearably slow and then often it crashes which makes it unusable.
John Cesta
Knights of Columbus
Haldex
Post by Haldex »
johncesta wrote: Tue Oct 26, 2021 7:38 pm Every sync for notes is unbearably slow and then often it crashes which makes it unusable.
Did you sync to iPhone?
AndreasX
Post by AndreasX »
Hello !
to get the notes from EPIM to iOS is a feature I miss really. In Android it is possible. All work done at the iOS App in the last time, was to upgrade it to ne newest iOS Version, that the app/synchronization works again with the newest IOS version.
Haldex
Post by Haldex »
I simply cannot understand why iOS devices, i.e. Apple's mobile devices, are so neglected. I think there are many iOS users who need this function as potential customers.
