I am connected to the internet. Whenever I save the database in Dropbox, it keeps giving me connection error. How should I do? With the previous version (9.10.6) it was perfect
Thank you
Denis
Essentil 9.10.7 bug with dropbox
Re: Essentil 9.10.7 bug with dropbox
What precisely does the error message say? Please also forward us the log file.
Thanks, would appreciate if you could also forward us the log file so that we could check what's going on behind the scenes.
- Denisov
- Has thanked: 13 times
- Been thanked: 33 times
How do I create the log file? Thanks
Best regard / Mit freundlichen Grüßen
You don't need to create it but get it from here: Tools->Options->Synchronization, Browse... and then forward to us. Thanks!
- Denisov
Ok, Thank!
Here is the dropbox log file!
- Dropbox_2021_10_26_21_18_04.log
- (37.46 KiB) Downloaded 77 times
Thanks, sync your database over to the new one using EPIM Synchronizer, that should fix the problem (which is with the sync token length changed by Dropbox recently).
