admin wrote: ↑Tue Nov 30, 2021 5:33 pm Okay, some words about the Previous Versions feature. You obviously confuse it with another feature that might be implemented in Notes (only?) in the future EPIM versions called "Revisions". When not the entire previous state of an item is being recorded but just its textual part. Hence your misunderstanding about history per-leaf, availability of assigned tags, etc. At the moment we're talking about previous versions for each of the different item types available in EPIM and it's going to stay more or less the way it is (with couple of additions like an ability to turn it off, clean it up or setup an amount of time to store previous versions for).
That does clear up a lot, I was certainly under the impression that it was revision history, because many system use history and revision as interchangeable terms.
Cool, in my case then my only request is the ability to turn it off then and that's already in the works.
