V10 note navigation is horrible.
Ramnee
Post by Ramnee »
This is awful, how did it get through QA testing?
Huge blocks of text to click, a scroll bar in average sized window, and cut off text when there is a scroll bar.
They also feel out of place, like they shouldn't even be in the navigation menu. They are more like minor toggle settings, more than unique views.
As for how they work. It's very awkward to switch between them. It would be much better if the main note tree was always on screen at all times and these new ones where in their own pane, sub-window, or flyout.
Ramnee
Re: V10 note navigation is horrible.
Post by Ramnee »
There's also issues with the task navigation as well. There's a large block of padding at the end of the new task mode.
We're aware of this, will be fixed/improved/changed in the next major update. Thanks.
