New place to select favorite, recently viewed and modified notes
VictorParkerPIM
Has thanked: 9 times
Been thanked: 70 times
Post by VictorParkerPIM »
Win11 Pro Ver. 21H2 (OS Build 22000.348 ) 64-bit, 32GB Ram, 4K Monitor, EPIM Pro Life 10.0 RC2
Where is the new place to select favorite, and recently Viewed?
DG
Beta Team
Has thanked: 29 times
Been thanked: 41 times
Re: New place to select favorite, recently viewed and modified notes
Post by DG »
It's in the navigation pane, under Notes.
VictorParkerPIM
Thanks DG,
I found it, but it wasn't easy, the navigational pane was unchecked.
I use shortcut keys to navigate to reduce clutter. It seems to me it should be in the Notes Navigation and visible.
MetalDrop
Been thanked: 189 times
Post by MetalDrop »
VictorParkerPIM wrote: Tue Dec 07, 2021 12:18 am Thanks DG,
I'm in the same boat, I use a copy of EPIM with navigation turned off as I only use notes, which renders favorites and recents unusable now in v10RC2.
There are lots of people who agree that it is currently in a poor location for a variety of reasons being discussed in the main release thread. It sounds like it may unfortunately be set in stone for v10, but will hopefully be moved to a better location in v10.1.
Filbert
Post by Filbert »
Can we please at least get hotkeys to switch between all and favorites before the end of the RC?
I can't use the navigation pane in my setup.
For future sake I read the release thread and I particularly like the idea of having both the main tree and favorites list on screen at the same time , thus eliminating the need to switch between states entirely.
Has thanked: 1616 times
Been thanked: 1133 times
Sure, will add shortcuts for these views. As for the future - seems that's the way we're going to do it :)
tamer
Has thanked: 4 times
Post by tamer »
Maybe it would be better to use the right click on the "Recent History" icon to show the favorites there? I have navigation pane disabled.
You can use shortcuts or the upper View menu.
tamer
Post by tamer »
Thx, I found the shortcuts. Btw, when the favorites selected + using quick search pane gives an error:
Code: Select all
Application: EssentialPIM Pro Portable 10.0  14.12.2021
Exception class: EArgumentOutOfRangeException
Exception message: Argument out of range.
Exception address: 004D81D0
Main thread ID = 11744
Exception thread ID = 11744
Object Logs:
11:49:22.965  AppRestore OK
11:49:22.855  SetViewMode OK
11:49:22.556  SetViewMode 3
11:49:22.540  AppRestore
11:47:19.650  DBSave OK
11:47:19.636  DBSave
11:32:19.641  DBSave OK
11:32:19.633  DBSave
11:17:31.611  Sync OK
11:17:31.608  CalendarsStore
11:17:31.608  SyncTasks OK
11:17:31.602  TasksStore
11:17:31.602  NewItems.Count 0
11:17:31.599  NewItems.Count 0
11:17:31.599  SyncInfo.Count 359
11:17:31.599  Events.Count 0
11:17:31.560  Events.Count 0
11:54:17.793  MainForm FormPan TBXToolbar2 TopPan Top2TB FindCB
11:54:12.724  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit
11:54:08.152  MainForm FormPan TBXToolbar2 TopPan Top2TB FindCB
11:53:55.474  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit
11:53:49.386  MainForm FormPan TBXToolbar2 TopPan Top2TB FindCB
11:53:32.646  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit
11:52:37.441  MainForm FormPan TBXToolbar2 TopPan Top2TB FindCB
11:52:21.657  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit
11:52:00.356  MainForm FormPan TBXToolbar2 TopPan Top2TB FindCB
11:50:29.066  ExceptionDialog DetailsMemo
Confirm this problem, will be fixed in the upcoming update version.
