Notes-tables on Android
Re: Notes-tables on Android
Are there any works in progress to implement table viewing and editing in EPIM for Android?
Regards, S.M.
- Has thanked: 1424 times
- Been thanked: 990 times
Yes, this is still something we have in plans.
I personally feel that the notes-table is quite urgent to implement. Cos if i create a page containing table using desktop version, the table will not appear in EPIM for Android, leaving just the table cell data. And I have to be very careful not to make any modification to that page in the EPIM for android, cos doing so will ultimately sync back to my desktop version, causing the table in the desktop version to disappear.
- dirmansyah
- Been thanked: 3 times
+1 and 1+ for table support on EPIM android.
On PC, I copied my note from another app and pasted it to EPIM PC Note module. The tables looked good.
I synched EPIM PC and EPIM android. On EPIM android note, there is no table but text with crowded format.
Thank you.
Thank you.
In my opinion, i think it will be good to highlight to all users that mobile version does not support table, otherwise if they purchased the license for it, mainly for the sake of the tables, they will get disappointed when they tries to sync the desktop version's table to mobile.
- Has thanked: 2 times
- Been thanked: 7 times
I want to add my vote to implement this feature as soon as possible. Have such a disparity in function between desktop and mobile app is very disappointing and frustrating. The issue raised by hanct, about tables getting trashed when sync mobile > Desktop, is especially bad karma.
v10 is WinEPIM. This feature will be added in Android EPIM.
When? v10.1, v10.5, 11.0.... v18.5, 2022, 2025? This statement is not any different or informative about when than any before it.
