Settings per Database
the george
Post by the george »
Feature I personally would like a lot to see:
Store settings per database and not for the application. I have several databases that just consist of notes and tasks, but if I remove everything else on the sidebar, I remove it for all databases. And its not just the display of needed modules, much more settings that I like to have different between databases.
Cheers and thanks for considering
Re: Settings per Database
Thanks for the suggestion. As a workaround you can use multiple Portable versions stored in different folders, in this case you're going to have separate settings for each of the instances.
bobmac1547
Been thanked: 10 times
Post by bobmac1547 »
I ran into an issue with EPIM settings when my SSD died. Because I was well backed up, I didn't lose anything but time (yeah, BUT! :? ).
While my sync settings were contained in the database, my backup settings were not. (They are in EPIM.ini under my user folder. I keep my databases on my separate physical D drive but my user folder is on the C drive which is the one that crashed.) So I had to re-create them.
Would it be possible to have the settings contained within the database so that a simple restoration of the database after reinstallation of EPIM would get the user up and running? Or at least save the settings in an ini file with the same name as the database and in the same folder?
I think that might make things more secure for us.
Just my 2¢...
Thank you for the detailed description about why this may be needed. Noted, indeed.
