Problem opening e-mail since update to epim 10.2
Since version 10.2 there is a problem opening an e-mail. When I try to open an email that just came in for the first time, I only see the header. The message area is empty. When I close and reopen it, the email becomes fully visible.
The same happens after restart of epim: When I open any e-mail from the list, the message area is empty. After closing it I can open all e-mails with success until a new e-mail comes in or EPim is restarted.
I use Windows 10 build 19044.1586, EssentialPIM Pro 10.2
- Has thanked: 33 times
- Been thanked: 8 times
Re: Problem opening e-mail since update to epim 10.2
here the same problemhaegok wrote: ↑Fri Mar 25, 2022 7:12 pm Since version 10.2 there is a problem opening an e-mail. When I try to open an email that just came in for the first time, I only see the header. The message area is empty. When I close and reopen it, the email becomes fully visible.
I have the same problem and replied to a previous topic. The only solution that seems to work now is opening the preview pane and that will open the email or use the scroll arrows at the top right to view the emails in sequence. I do not typically use the preview window since I don't want to accidently open a suspicious email. Please fix this!haegok wrote: ↑Fri Mar 25, 2022 7:12 pm Since version 10.2 there is a problem opening an e-mail. When I try to open an email that just came in for the first time, I only see the header. The message area is empty. When I close and reopen it, the email becomes fully visible.
Well now I don't know what to say, but the email is working properly again - virus? gremlins? FBI? URG!!!
I'm having the same problem.
When I open an email (double click in list) the window opens, the contents appear briefly, then disappear. Nothing I do changes this.
EPIM 10.2
Windows 10.0.19044 Build 19044
EPIM 10.2
- Has thanked: 1418 times
Please record a small video demonstrating the problem so that we better understand what to look for in the program's code. Thanks!
- Your V Gal
- Has thanked: 3 times
- Been thanked: 2 times
I'm not sure how to record my screen on Win11 machine? hmb seems to have his issue resolved, mine is not. If I have the Preview pane turned off, and using the ALL INBOXES folder, if I double-click on a new mail item, the window opens and sometimes I will have a brief flicker of the message then it goes blank -- all on it's own. Then, when I close the mail message window and go back to the same item and double-click on it, the mail item opens normally. This is with Win11 and the latest 10.2 EPIM update.
Hi, Well, the Email is back to doing the same thing again - not appearing when clicked.
I am using Windows 10 and I think I can get a video, but there is not much to see. As I said, I open the email window, go to my inbox, and click an email - I sometimes get a short flicker of something but the email information area is empty. IF I OPEN THE PREVIEW WINDOW below the messages, the emails seem to open properly and I can view the messages. Another oddity is - if I open an email with text (no graphics or links) those emails seem to open OK. Here is another bit of info - if I close the preview screen and click one of the messages that opened (with graphics) then it DOES OPEN PROPERLY.
Another problem - which I am not sure if it is related here - I have hyperlinks to some notes (in the Notes Tab) that worked, but now it seems that I need to add in a ABSOLUTE PATH for the links, otherwise, the links do not work. Without the absolute path WITH A DISK DRIVE LETTER, a CTRL+Left mouse click or Alt+Left mouse click does not open a link.
Hi
I have exactly the same problem.
I have not a virus.
This appear in the new version
But if you resend e-mail this appear perfectly. It´s only when you open the email
Best regards
I have not a virus.
Best regards
This problem should be fixed in EPIM 10.2.1. Please update.
Downloaded 10.2.1 and installed and YES the problem has been fixed - Thank you EPIM Team!
I also checked and the absolute vs relative hyperlinks are still not functioning properly. I use the Insert Hyperlink feature in EPIM to insert a Notes link, but unless I edit the link and make it absolute (add the disk drive letter) the link does not open using either Ctrl+left mouse click or Alt+left mouse click. Not sure if this happened in 10.2 this is when I noticed it. I use this feature in many of my notes and I don't want to have to go back and modify all my hyperlinks. Since the Email Issue is fixed, should I create a new topic on this problem?
Thanks for the confirmation! Yes, would appreciate if you create a new topic about the problem with internal links. What I'd also ask you to do is to create a new EPIM database file and copy-paste couple of non-important items into it and check if the issue will be reproducible there. If so, attach that db to your next post.
