Application crash at launch - 10.1.1
Intermittently, EPIM Pro crashes right after the password has been entered. This is not new to version 10.x but seems to happen more frequently.
If I just press OK everything is fine. But if I press Send (error report), EssentialPIM Pro just freezes and needs to be killed in task manager.
- Has thanked: 1412 times
Re: Application crash at launch - 10.1.1
Next time this happens, please click on the Details button and copy paste the exception log here, we could get better idea as to why it happens then. Thanks!
At second launch today (now on version 10.1.2) it happened again.
Error dialog text:
Details:
Error dialog text:
Code: Select all
XSQLDA index out of range.
Code: Select all
Exception log with detailed tech info. Generated on 10-03-2022 14:26.
Application title: epm.epim - EssentialPIM Pro
Application: EssentialPIM Pro 10.1.2 17-02-2022
Exception class: EIBClientError
Exception message: XSQLDA index out of range.
Exception address: 007788C4
Main thread ID = 18668
Exception thread ID = 18668
Object Logs:
14:26:17.799 SetViewMode OK
14:26:17.217 SetViewMode 6
14:26:12.459 DBOpen
14:26:17.199 MainForm
14:26:12.930 PasswordDialog PasswordEd
14:26:12.454 MainForm
Memory: 32659; free 17661
Display: 1920x1200 pixels, 32 bpp, 96 PPI
Updates: 1
Last update: 10-03-2022
Please also forward us the SQL* log file. Click on Tools->Options->Synchronization, Browse... to get to it. Thanks!
Same error at first launch today - SQL log (SQL_2022_03_11_08_31_27.zip) attached:
Code: Select all
Exception log with detailed tech info. Generated on 11-03-2022 08:31.
Main thread ID = 7864
Exception thread ID = 7864
Object Logs:
08:31:32.597 SetViewMode OK
08:31:31.965 SetViewMode 6
08:31:27.395 DBOpen
08:31:31.950 MainForm
08:31:27.830 PasswordDialog PasswordEd
Memory: 32659; free 25861
Updates: 1
- SQL_2022_03_11_08_31_27.zip
- (1.99 KiB) Downloaded 71 times
Thank you. Please downland and install the following custom build:
https://www.essentialpim.com/download/t ... Pro101.exe
The problem should be fixed in it. Would appreciate if confirm that.
Thank you very much.
This custom build have now been installed.
Please note, as this problem is intermittent, it might take a while, before I "trust" the fix, and get back.
No problem. How has it been performing since then?
Good, thanks for the update.
Now at version 10.2.1 - Still no issues.
So let's say: Problem fixed!
Good to hear, thanks for the confirmation!
