Ctrl Drag&Drop
- Has thanked: 1418 times
Re: Ctrl Drag&Drop
Yep, seems like a bug, will be fixed in the next update. Thanks!
Re: Ctrl Drag&Drop
Any progress to report on this?
I've used this regularly, but it seems to have gone missing somewhere between V9.x and the early V10s. - CKM
Re: Ctrl Drag&Drop
Yep, working fine on 11.0 Beta3. So you should expect a fix soon with the 11.0 final release version.
