Hello everybody.
EPIM Pro 10.2.1 on Windows 10
Even in previous versions, if I sort the categories, Edit -> Category -> Edit Categories - the new order is not kept.
Any suggestions?
Thank you
order list categories
- Has thanked: 1419 times
Re: order list categories
Unable to reproduce this. Please try with a new DB, will it be the same?
It only happens sometimes.
Now I tried again to edit the sequence and save right after. For now it's ok.
I don't know if it can be useful, but I have noticed that when syncing on Android, some categories are not in the right sequence. Not a problem, it's just to add a few details.
I'm not sure, but it seems to me that when it changes,
returns the old sequence of when I entered the categories for the first time.
However it is not a problem if the categories are sometimes mixed, EPIM is still a great software.
I apologize again for the english from google translator.
Thank you.
Thank you.
I still made some tests. The order of the categories is changed (but not always) after changing the category of a task on Android and synchronizing EPIM PC.
I hope this report is useful,
Thank you.
Thanks for the update. By saying you change a category you mean that you rename it?
i mean from android i select a different category from the list.
But I have tried again now and everything works fine.
