EssentialPIM 11.0 Release Candidate
Re: EssentialPIM 11.0 Release Candidate
Error when select all tasks with Ctrl+A:
Code: Select all
Exception log with detailed tech info. Generated on 6/23/2022 3:50 PM.
Application title: temp.6296AEB3.epim - EssentialPIM Pro Portable
Application file: J:\-- portable apps\[portable] EssentialPIM\EssentialPIM.exe
Application: EssentialPIM Pro Portable 11.0 RC1 6/20/2022
Exception message: Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000.
Exception address: 0157CEE8
Main thread ID = 2636
Exception thread ID = 2636
Object Logs:
15:50:22.334 DBSave OK
15:50:22.239 DBSave
15:48:17.113 SetViewMode OK
15:48:16.049 SetViewMode 2
15:48:14.232 DBOpen OK
15:48:14.093 SetViewMode OK
15:48:13.739 SetViewMode 0
15:48:13.020 DBOpen
15:48:10.806 DBClose OK
15:48:09.323 DBSave OK
15:48:09.274 DBSave
15:48:08.482 DBClose
15:48:01.369 DBSave OK
15:48:01.314 DBSave
15:47:37.868 SetViewMode OK
15:47:37.617 SetViewMode 1
15:47:36.477 SetViewMode OK
15:47:36.401 SetViewMode 3
15:47:22.618 DBSave OK
15:47:22.239 DBSave
15:48:47.967 MainForm FormPan FormPan2 ToDosForm ListsTC ToDosVT
15:48:44.759 ExceptionDialog OkBtn
15:48:43.964 MainForm FormPan FormPan2 ToDosForm ListsTC ToDosVT
15:48:41.873 ExceptionDialog OkBtn
15:48:41.592 MainForm FormPan FormPan2 ToDosForm ListsTC ToDosVT
15:48:36.661 ExceptionDialog OkBtn
15:48:33.345 MainForm FormPan FormPan2 ToDosForm ListsTC ToDosVT
15:48:31.937 MainForm FormPan TBXToolbar2 TopPan TopTB AddBtn
15:48:30.487 ToDoDialog Panel1 CategoryCB
15:48:27.224 ToDoDialog PageControl1 ToDoTS TitleEd RichViewEdit
Exception stack
Stack list, generated 6/23/2022 3:50 PM
(0117BEE8) [0157CEE8]
(000D372F) [004D472F]
(00233226) [00634226]
(00233297) [00634297]
(0023840E) [0063940E]
(0023780F) [0063880F]
(01258A7C) [01659A7C]
(015A0197) [019A1197]
(015A0253) [019A1253]
(015A0B34) [019A1B34]
(015B3A64) [019B4A64]
Memory: 32687; free 24400
PrevExceptions:
15:46:24.831 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:46:37.301 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:46:39.625 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:46:42.792 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:46:47.153 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:46:48.668 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:47:11.222 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:48:41.576 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:48:43.960 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
15:48:47.962 Access violation at address 0157CEE8 in module 'EssentialPIM.exe'. Read of address 00000000
Updates: 1
Last update: 6/23/2022
EPIM Pro 12 Portable
This multiple calendar is awesome. Thank you so so much.
I agree, it keep on getting better and better.
I have a question.
How I can move one of the synced "Category" in Epim = "Calendar" in google to separate new "Calendar" in Epim?
Let's say I made new "Calendar B" inside Epim. I want to see Category B inside this new "Calendar B". Calendar B is synced with "Google Calendar B"
I can click each appointment and move to newly made "calendar B" ... is this the only way?
I was expecting I was able to have each Epim Calendar has each sync, so, expected to have Epam Calendar A will sync Epim Category A with Google Calendar A, and Epim Calendar B will sync Epim Category B with Googla Calendar B.
Thanks for the help.
I have a question.
New possibilities, new wishes...
Since we can now manage different calendars independently of each other (a super good idea!), I would find it excellent that when you want to set a new appointment, a default calendar can be defined. In my case, I would set the private calendar as the default so that it is not possible for private appointments to appear on the group calendar by mistake.
I tried version 11.0 RC1. Very very nice.
In my opinion, it would be very useful to have a button in the top bar in the Tasks to directly activate the custom view bar. Or, even better,
always have the drop down menu of templates always available in the top bar without having to open the custom view bar every time. This second solution would really be the TOP for me!
Thank you
Thank you
- Has thanked: 13 times
- Been thanked: 44 times
Hi there,
cannot download the RC 11.0.
It always says, download is unsuccessful.
On my side only or anybody else has same experience?
Thanks!
Thanks!
Hi there,
so I finally managed to download RC 11 from that link. The first 10 tries were unsuccesful.
After installation there was a new entry in windows7 start menu "EssentialPIM Pro Beta". The old entry still was there (starting 10.2.1).That's how it is supposed to be?
When starting RC program says that I'm about to open DB a second time, which is not the case (nothing else is open at that time).
Clicking on yes, to start it anyway, on next window program says that some shortcuts cannot be registered. It remains like this, even when I go to "Standard" in options (as to shortcuts).
AND
Sync-status-window (EPIMcloud) when closing program is hidden in task bar behind icon of main window. Hovering with mouse over those icons, it doesnot show any content. When I click on the icon in task bar, which should be sync-status-window, it opens and shows correct content
What to do?
AND
What to do?
- Been thanked: 1134 times
a8907433, please update as the language file as the app files. Better yet install the portable version into a new folder and see if the issues are gone. Looks like some of the files weren't updated properly.
FireBrand2026, we're on it, I cannot promise quick implementation and that it's going to look exactly like you suggested, although changes are already planned and updates are on the way.
Haldex, good to know you managed to make the sync working, thanks for the update! Regarding the default calendar - so far new events will be created in the selected calendar, although your suggestion noted, thanks! As for the sync error - please forward us the sync log file.
paulfb, would appreciate if you forward us the log file of the failed sync. Will be able to better understand what went wrong there. Agenda view in Calendar, confirm this problem, will fix. And sidebar in Notes works ok on our side. Are you on a Portable version?
ЛеонидЛогинов, it works as expected on our side. If possible, please make a short video demonstrating how the caldav sync works on yours. As for the tasks - you'd like them to be divided into accounts, as well? Regarding the strange logic - I think you're the only one who utilizes that scenario, so no changes are planned with it, yet. Offline icon shows symbolic network backbone
miira, we're unable to reproduce the first point you mentioned, please make a short video demonstrating it. As for the second point - confirm the issue, will fix it.
1048576, unable to reproduce the described issue. Please make a short video demonstrating it.
epuhzgis, you can move different calendars all together with their events from one account to another (check the calendar's properties). all the calendars under the google calendar account will be able to sync with google. Hope this answers your request.
lorymax, thank you for the suggestion, will think about it.
poet-man, all works as expected.
Attached.1048576, unable to reproduce the described issue. Please make a short video demonstrating it.
- Video_2022-06-25_200818.wmv
- (1.76 MiB) Downloaded 190 times
Thank you, clear now. The tasks need to be grouped, then the error will appear. Will be fixed in the next update.
I did so, but this had no effect. But I could not see, how the German language file should have any effect- I use EPIM in the English version.a8907433, please update as the language file as the app files. Better yet install the portable version into a new folder and see if the issues are gone. Looks like some of the files weren't updated properly.
I found that, when I enable/disable the sidebar in calendar, I can take the edge of the sidbar-window and pull it to the edge of the screen- then the sidebar is gone.
Only drawback of this method is, EPIM is not remebering this, after a new start the empty sidebar is there again.
I will unpack the next release in this directoy- I delete all exept the database and the .ini file with my license.
I only now start my regular using of V11, in adition to using V10. When all works fine, I move all data (db + program) to my regular portable directory.
You mean you checked the language file or installed EPIM into a new folder? It doesn't matter which of the language files you use, what matters is that it's properly updated.
I can confirm the issue with Sidebar reappearing after EPIM's restart, will fix it.
Every time I test a new version, I test it in an empty directory. I only use the porttable versions.
Another issue: I just tried to use the "Autotype" in passwords: First try (Autotype in top menue): EPIM not responding, had to close it with task manager. Second try: "Autotype" on the top menue is not working. Right clicking on the password entry "Autotype" is working.
Unable to reproduce either of the issues, unfortunately.
I tried again, click on "Autotype"- EPIM hangs. Here you see my Taskmanager: One EPIM (V10) is running, V11 is inactive (not reacting at all).
