Add sticky Icon above Main Calendar
VictorParkerPIM
Has thanked: 9 times
Been thanked: 51 times
Post by VictorParkerPIM »
I think it would be very useful to have a Sticky Icon in the main tool bar above the big Calendar, like it is in Notes.
A list of names and telephone #'s for doctors' Appointments or could be used for many other things.
Once the sticky is setup, I would make it read-only.
I think I would use it a lot. I know you can pin a sticky, but it might not be there when needed.
Drag and drop from the sticky works well for this. Could this be added to the main tool bar?
Thanks,
Intel(R)Core (TM) i7-8700 CPU @ 3.20GHz, Win11 Pro Ver. 21H2 (OS Build 22000.778) 64-bit, 32GB Ram, 4K Monitor, EPIM Pro Life 11.0 RC1
Re: Add sticky Icon above Main Calendar
You mean you'd like to have a feature to make events sticky same way as you can currently make notes sticky?
VictorParkerPIM
No, I mean I want to pull up a note that I have already made sticky and put the data in appointments while in calendar mode.
VictorParkerPIM
Disregard, I can see now that it can't work the way I first thought it would.
You can do it if you pin and minimize a sticky note, it will be visible in the Calendar then.
VictorParkerPIM
Yes, I know but the collapsed sticky is visible all the time, even in other programs.
I thought an Icon could show or hide the pinned sticky.
This idea is probably not time worthy, anyway I found a way to do it with a program I have. " PasteItIn "
Thanks,
I'm waiting on final ver. of 11.
Ok, got it, thanks. The final release version of EPIM 11 will be available during this week.
VictorParkerPIM
Great!
