I have 2 databases that I use daily. In both databases, when I do an advanced search, WEPIM keepas hanging if I search in all modules. No issues if I search in only one module.
To give you an idea of the database sizes, in one of the databases I have:
- 5203 appointments
- 6582 tasks
- 323 notes
- 1339 contacts
- 94 password entries
Is there a limit to the amount of items for advanced search in all modules to work properly?
I am not able to reproduce if I do an advanced search in all modules in a new completely empty database. Does this indicate it is an issue in these 2 specific databases? If so, how can I try to pinpoint what exactly is causing the issue?
WEPIM keeps hanging in advanced search (all modules)
Re: WEPIM keeps hanging in advanced search (all modules)
The database isn't that big and it should work normally. Please check and let us know if EPIM 11 is able to work better in that regard.
