task widgets: priority filtering separated from filtering in app itself
Currently, AEPIM task widgets follows priority filtering of the app itself: if the app only shows highest priority tasks, so does the widget.
Please consider changing, so that AEPIM task widgets can show all tasks, while app itself shows only highest priority tasks, etc. ...
Thanks in advance.
Kind regards.
Thanks in advance.
Kind regards.
Re: task widgets: priority filtering separated from filtering in app itself
Thanks for the suggestion, noted.
