EPIM changes the tasks
lorymax
Been thanked: 7 times
Post by lorymax »
I report a new very very annoying problem.
It doesn't always happen, but EPIM often sticks all the text by eliminating all the "returns". This is an extremely annoying problem that changes many tasks (not all).
I made many attempts, but in the end I managed to register the problem.
I'm not sure sync is the cause, but the problem has already occurred many times since the latest updates. It had never happened before.
I use EPIM Pro 11.1 and AEPIM 6.0.5
I attach the video.
Thank you.
20220923_213028.mp4
(2.46 MiB) Downloaded 61 times
lorymax
Re: EPIM changes the tasks
Post by lorymax »
I add that the problem concerns almost all tasks.
I tried to modify them manually by re-entering all the returns, I also tried to create a new task by copying the text with the correct returns, but the problem is the same. After a while, everything sticks back together.
This is a big problem for me.
Thank you
We're working on the problem. Thanks.
lorymax
Post by lorymax »
update.
I went back to AEPIM 5.8.7 (always with WEPIM Pro 11.1)
I did some tests and the problem never occurred again. Until now.
lorymax
Post by lorymax »
At this point I would say that the problem is caused by AEPIM 6.0.5
Since I returned to AEPIM 5.8.7 everything works fine.
Is it possible that AEPIM also caused the character substitution problem that I had already reported? At the moment even that has not happened anymore. https://www.essentialpim.com/forum/view ... 16#p125516
thanks
lorymax wrote: Mon Sep 26, 2022 8:34 amIs it possible that AEPIM also caused the character substitution problem that I had already reported? At the moment even that has not happened anymore. https://www.essentialpim.com/forum/view ... 16#p125516
I seriously doubt it.
