Highlight if search is active
daho2018
Has thanked: 15 times
Been thanked: 7 times
Post by daho2018 »
Hello all,
it happens to me again and again that I wonder why not all data is always displayed. Then I remember that there is an entry in the upper right corner of the filter, which means that the filter is currently active.
Would it be helpful, if the search is active, that the input field is displayed in a different color? Either the content or the frame of the input field to be able to immediately recognize that there is currently a filtered view?
Greetings
Re: Highlight if search is active
Thanks for the suggestion, will think about possible ways to improve this.
