Add to the appointment right click menu.
- Has thanked: 9 times
- Been thanked: 50 times
When I have an appointment, quiet often it is canceled or rescheduled.
Would you add two more items to the right click completion menu?
1. Cancel: and hide the appointment.
2. Reschedule: and have a pop up to change the appointment to another date.
- Has thanked: 1412 times
Re: Add to the appointment right click menu.
1. Would this somehow be different than the regular "delete" action?
2. Do you think a pop up should look different than the one you get when using the "edit" option?
1. The difference is if you delete, all the information is gone.
Cancel: and stamp Canceled and hide it all in one step. You'll know it was not a completed appointment.
There maybe an important name or telephone # or other info. needed to
reschedule later. un-Hide and you have all your information
2. I agree here, after thinking about it it's best the way it is.
1. So you see it acting much like a completed event with an additional option to show/hide completed (cancelled in this case)?
Understood, thanks for the suggestion.
- ecsaltz
- Has thanked: 30 times
- Been thanked: 77 times
Here's how I handle cancelled appointments with information I don't want to loose as I would with deleting them:
I created a new calendar called "Cancelled". I don't normally display it. For an appointment on the "Main" calendar that I want to cancel, but not delete, I simply change it's calendar to "Cancelled". This way, if I only display the "Cancelled" calendar, I can see all my cancelled appointments. I can re-schedule a cancelled appointment by simply changing its calendar to the "Main" one.
I am not saying that there isn't a better way to do this, I am just using the existing capabilities of WinEPIM v11.1.1 until an alternative method is introduced.
ecsaltz:
Thanks!
I'll have to check in to that and see if it works for me.
Thanks!
- ecsaltz
In the WinEPIM beta v11.2, there is a new cancel capability that works very much the way you requested. Perhaps in a week or so, there will be a RC for you to try.VictorParkerPIM wrote: ↑Thu Dec 01, 2022 4:06 pm ecsaltz:
Thanks!
ecsaltz,
I saw that already and it seems like what we were talking about, Thanks!
