EPIM 11.2 BETA1
lorymax
Been thanked: 7 times
EPIM 11.2 BETA1
Post by lorymax »
I see you have added a customizable toolbar.
However, it is only possible to hide commands that are already present by default. It would be useful and interesting to be able to add other commands such as activating the customized view bar or other things.
Thank you.
Re: EPIM 11.2 BETA1
Customized view bar is something else and you can show/hide it from the View menu. Which other options you have in mind? Thanks.
lorymax
Re: EPIM 11.2 BETA1
Post by lorymax »
I don't know if it's possible, but it could be handy to add a button for any menu item.
It's just for convenience, it's certainly not an essential thing.
P.S. - I confirm that with the latest versions I haven't had any of the problems I reported in other posts (for example reshuffled categories,
characters replaced on float tasks) at least for now.
thank you
Re: EPIM 11.2 BETA1
Understood, thanks for the clarification, every single opinion matters to us :)
lorymax
Re: EPIM 11.2 BETA1
Post by lorymax »
In EPIM Pro 11.2BETA1, the consolidated view is no longer available in Tasks. Was it intentionally removed? :shock:
For me it is a very important view that I use a lot.
Also the "list of origin" column now contains the subject of the task and is also displayed in the plain view, instead it was hidden before.
Re: EPIM 11.2 BETA1
Yes, the consolidated view was removed as we're testing a new feature - namely, you can select any number of lists on the left now to create your own consolidated view.
As for the list of origin issue - confirm it, thanks!
lorymax
Re: EPIM 11.2 BETA1
Post by lorymax »
Ok but this could have been done even before by using the filters on the "list of origin" column in the consolidated view.
However on 11.2BETA1 the "list of origin" column doesn't work well, it displays the task name instead of the list name.
I attach a short video.
epim.mp4
(1.38 MiB) Downloaded 61 times
lorymax
Re: EPIM 11.2 BETA1
Post by lorymax »
today on 11.2BETA1 the problem on the float task happened again, when EPIM updated it.
I'm running 11.1.11 Pro for my database and that problem hasn't occurred in quite some time.
lorymax
Re: EPIM 11.2 BETA1
Post by lorymax »
Okay! with the BETA2 the problems I reported seem to be solved. At least for now.
The ability to select all tasks by clicking on "local tasks" is excellent - it becomes a consolidated view.
Very good. Thank you.
