IO can find no way to associate EPIM with the Windows 10 .ics file type.
Using the Settings>Default apps by file type is of no use. The default allows selecting something from the MS store only which is of no use.
What to do?
EPIM as default calendar in Windows 10
- Has thanked: 1242 times
- Been thanked: 861 times
Re: EPIM as default calendar in Windows 10
It should work, we're talking about the Desktop version, not the Portable one? If so, will have a look at the problem.
