No date/time fields in tasks
poet-man
Has thanked: 10 times
Been thanked: 31 times
Post by poet-man »
Hi there,
a problem which has been there some time ago and comes up now again ...
Trying to create a task in 6.0.10 via plus sign in calendar doesnot show date/time fields.
Why and how to solve.
Has thanked: 1407 times
Been thanked: 977 times
Re: No date/time fields in tasks
This seems like a bug. We will fix it in the future versions of the app. Thanks.
poet-man
Post by poet-man »
admin wrote: Wed Mar 29, 2023 1:13 pm This seems like a bug. We will fix it in the future versions of the app. Thanks.
Is there some way to workaround? Or how should I create a task?
Sorry, it seems I have misinformed you earlier. If you reinstall the app, the date/time fields should be visible again.
poet-man
Post by poet-man »
admin wrote: Wed Mar 29, 2023 4:19 pm Sorry, it seems I have misinformed you earlier. If you reinstall the app, the date/time fields should be visible again.
I will have a try.
However, this seems to occur, when all data in all modules is deleted (you remember the option in menu to delete everything), to sync AEPIM to epimcloud afterwards, to get all data again. After this the fields are not there anymore, when creating a new task.
Edit:
Reinstallation did it. So - it should possibly be found out, why it happens after purging all data without reinstalling
Ahha, now we know the cause of the issue, thanks! Will address it in the next update.
