EPIM 11.5.1 - Offscreen - not responding
- Has thanked: 8 times
- Been thanked: 7 times
Since this latest update, I'm seeing this behaviour
1. Open up EPIM - Starts in in the bottom left of the screen - unresponsive and mostly offscreen
2. Go to Task Manager - Kill Task
3. Open up EPIM. Starts on the actual screen - but again unresponsive
4. Go to Task Manager - kill task
5. Open up EPIM - works normally
I've rebooted and repeated these results five times, so not sure if something to do with the new update?
Regards
Xine
Regards
Xine
Re: EPIM 11.5.1 - Offscreen - not responding
You can try waiting a bit longer when you start the program for the first time, as it may require some additional time to work on your database.
Thanks for the reply. When it's starting, it's not trying to open the DB (From the screen) but I'll give that a go - give it half an hour to do 'something' and I'll let you know
Cheers
Cheers
- Has thanked: 13 times
- Been thanked: 44 times
Donot know whether this is possible ... did you try to start EPIM in windows' safe mode?
