Paste text from clipboard in the Notes
marmegint
Post by marmegint »
Hello!
When I copy a text from the clipboard onto an empty page in notes, the empty lines (text segmentation) disappear.
The way to get around this problem at the moment is i to write something in a few lines on the blank page (even just letters) and insert the text from the clipboard between these lines.
My phone is:
AEPIM v6.0.11
Andoid 9, Build 55.0.A.10.26
Sony Xperia 1
Thank you.
Has thanked: 1424 times
Been thanked: 990 times
Re: Paste text from clipboard in the Notes
Thanks for bringing the issue to our attention. We will investigate the possible cause and address it in the next update to ensure a fix.
marmegint
Post by marmegint »
Hello!
One more piece of information if it helps you find the error or fix it.
This also happens if I copy several lines of text with empty lines from another application into a task in the AEPIM Tasks module where in the Text section has not yet been written nothing.
I also tried changing the encoding of the texts (ANSI, Unicode, UTF-8), but there was no change.
My phone is:
AEPIM v6.0.14
Sony Xperia 1
Thank you.
