PRO activation problem
- Laurent C.
- Has thanked: 5 times
- Been thanked: 14 times
Re: PRO activation problem
It works — but so weird !!!
EPIM Pro + EPIMA Pro (Android) / W10 Pro 64 bits FR + Office 2019 Pro Plus / Pixel 7 Pro
Hi folks
I've just encountered this problem also - i.e. I previously bought the pro version of AEPIM but this is now not being recognised.
AEPIM version: 6.0.14
Phone: ASUS Zenfone 8, Android version 13
AEPIM Pro purchase date: 23/04/2014
For ADMIN: I'll PM you the order number as per instructions earlier in this thread.
Cheers
Paul.
Cheers
Paul.
- Laurent C.
Hi paulvp, read just that...eddie_s79 wrote: Mon Aug 28, 2023 11:51 amThank you very much @lorymax.lorymax wrote: Mon Aug 28, 2023 11:32 am I too had the same problem recently. The solution is always the same. Install AEPIM 5.8.7 which you can download from the link below. After that update to the latest version from play store.
https://essentialpim.zendesk.com/hc/en- ... sentialPIM
Additional info (maybe helpful for others): I had also problems getting the EPIM Android system account back to work to see the contacts in the dialer. After I unchecked and checked the EPIM system account checkbox, and EPIM recreated the account back, everything is now working like before.
Thanks for that
. I did read that post but wasn't sure about how to install something on my phone that didn't come direct from the Play Store. I'm sure I can figure out if I try but thought the path of least resistance might just be to get the admins to activate my pro version, since I still have the order number.
Cheers
Paul.
Cheers
Paul.
- Laurent C.
No, just do it, accept the installation from unknown sources (not unknown = EPIM), and install latest version just after... Rgdspaulvp wrote: Sun Sep 24, 2023 10:08 pm Thanks for that. I did read that post but wasn't sure about how to install something on my phone that didn't come direct from the Play Store. I'm sure I can figure out if I try but thought the path of least resistance might just be to get the admins to activate my pro version, since I still have the order number.
Cheers
Paul.
- Laurent C.
The admins will ask the same - believe me : it was exactly my past issue - just uninstall the version you have on Android + install the AEPIM 5.8.7 + install the Google Play version - Regards.
- Laurent C.
You're welcome
- Laurent C.
Yes, it's always the same issue on Android 14 — and strangely it's also always the old AEPIM 5.8.7 that needs to be installed 1stlorymax wrote: Sat Feb 03, 2024 10:04 pm Update. The problem is always the same even on Android 14 (Xiaomi Redmi Note 12) and even in this case the solution I wrote above works.
- Has thanked: 35 times
- Been thanked: 9 times
This process does indeed work (or it did here...) - of course, then you need to Re-sync with desktop (if appropriate)
uninstall AEPIM 6.0.5
download AEPIM 5.8.7 via this link: https://www.essentialpim.com/download/o ... _5.8.7.apk
install the downloaded AEPIM 5.8.7
start AEPIM 5.8.7. Just a few seconds later it automatically found my license and Pro-featuers became available
update to AEPIM 6.0.5 and Pro-features remained available.
- Laurent C.
