Run at startup does not work.
- Has thanked: 9 times
- Been thanked: 51 times
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Run at startup does not work.
We are currently unable to reproduce this issue. To troubleshoot further, we recommend backing up your EPIM.ini file, removing it, and checking if it resolves the problem. Thanks!
Please guide me to where the Epim.INI file is located, has it been moved?
That depends on whether you are using the installable edition or the portable edition of EPIM. If you are using the portable edition, the EPIM.ini file should be located in the application's directory. If you are using the installable version, the EPIM.ini file should be located in your Windows user directory. The path to the file would look something like this: C:\Users\windows_username\AppData\Roaming\EssentialPIM Pro.
Deleting INI file didn't fix it, but I found the problem.
EssentialPIM was turned off in Windows Apps > Startup.
Must have happened in recent windows update.
Win11 Pro Ver. 22H2 (OS Build 22621.2361 64-bit, 32GB Ram, 500gb M.2 SSD, 4Kmon., Desktop EPIMPro Life 11.7.1
