Two Leaf 1s on new note.
VictorParkerPIM
Has thanked: 9 times
Been thanked: 70 times
Post by VictorParkerPIM »
When I make a note with Add a Note, and click Sticky Icon, why does it put two Leaf 1s on the note?
Win11 Pro Ver. 22H2 (OS Build 22621.2361 64-bit, 32GB Ram, 500gb M.2 SSD, 4Km, EPIMPro Life 11.7.1, Joined: Feb 02, 2010
Re: Two Leaf 1s on new note.
Could you please provide a short video demonstrating the issue? We have been unable to reproduce the problem on our end.
VictorParkerPIM
1. Click Add a note.
2. Name it.
3. Click to make it Sticky.
4. Sticky Note has two Leaf 1s.
Not a big problem, but it's not right.
On our side, following your list of steps, there are no two instances of "Leaf 1".
VictorParkerPIM
On my side it is repeatable every time I select sticky right after naming note.
It only happens when using Add a Note.
So far not causing any issues.
Thanks for checking it out.
johncesta
Been thanked: 11 times
Post by johncesta »
if I click add a note then a sticky it does 2 leafs. I don't even have to name it.
1. Add a note
2. add sticky
John Cesta
Knights of Columbus
VictorParkerPIM
Thanks John, for verifying the issue.
johncesta
Post by johncesta »
I am not to hip on the "leaves" but when I synced with my android only one came over. But on the laptop when I added a little text to each one they both synced to my phone.
John Cesta
Knights of Columbus
ecsaltz
Has thanked: 32 times
Been thanked: 91 times
Post by ecsaltz »
My experience with this issue (v11.7.2):
1. If I type in "Add a note", press "Enter", select "Sticky": expected behavior.
2. But, if I do the above, but instead of pressing "Enter", press "Move below lists" icon: I get the double leaf issue, consistently.
Cell phone: AT&T FirstNet Samsung Galaxy Z-Fold 6, Android 14 - linked with Garmin Fenix 6 Pro wrist watch and Fitbit Sense wrist watch.
ecsaltz, thanks, we have successfully reproduced the problem and we appreciate your assistance in identifying it. This issue will be addressed in the next update of EPIM.
johncesta
Post by johncesta »
are victorparker and I chopped liver? haha
John Cesta
Knights of Columbus
VictorParkerPIM
John,
WE are the forgotten two. :)
johncesta
Post by johncesta »
yea, that's the way it goes I suppose. :(
John Cesta
Knights of Columbus
VictorParkerPIM
Another problem found with naming Leafs when creating new notes.
"Add a Note" above left sidebar works different from Insert Note. "New Note, with Insert Key"
When a note is created with "Add a Note", this only happens when the main toolbar is on and click the Sticky Icon. "Two Leaf 1's "
*When a new note is created with Insert Key and check Sticky checkbox the Sticky note does not have a Leaf name at all.
VictorParkerPIM
It keeps changing, it wont put any leafs on the sticky now unless the main note has more than one leaf.
Please don't ask me to try a new database. Other users have had similar issues, but they all seem to be a little different.
