Read-only calendars can't be modified
Good Night!
When I try syncrhonization by outlook.com come the respost: "Your request can't be completed. Read-only calendars can't be modified".
For this instance I have optated for google account with sucess, but I don't understand what the reason for the fail when choose the outlook.com
Any sugestion?
Grate.
Dudu.
Any sugestion?
Grate.
Dudu.
Re: Read-only calendars can't be modified
To provide more information, we'd need to review the synchronization log file, please forward one to us. You can obtain this file by following these steps: Go to Tools -> Options, select "Logs Folder", and locate the file that starts with "OutlookComSync". Thank you!
I use the EssentialPIM Pro 11.7.3 version. When I click on Tools there are the following icons:
Advanced Search/Identifier Explorer/Attachment Manager/Send Newsletters/Print Names/Print Envelopes/Password Creator/PGP Setup Wizard/Manage PGP Key/Configure/Language. But I can't find the icon for Options.
Please see the screenshot below.
I am attaching the file as agreed.
- OutlookComSync_2023_11_20_08_05_06.zip
- (5.37 KiB) Downloaded 180 times
Great, we've received the log. Thank you for providing it. I will keep you updated on the progress and let you know if we require any additional information.
According to the log file, the issue pertains to the event named "BLOQUEADO," which should be saved in the read-only calendar. However, in EPIM, it is not possible to create events directly in read-only calendars. Can you remember any alternative method or workaround that might have allowed for this to be achieved?
Dear Administrator.
Initially thanks for the help but I can't understand the question.
As I'm using Google account synchronization I prefer to keep this other useful method.
Hugs.
Dudu.
Hugs.
Dudu.
In one of the read-only Outlook calendars in EPIM, there is an event labeled "BLOQUEADO". Could you please provide more information about its origin or source? Thank you.
I need frenquentely dedicate on another job and how I can't work in two locations simultaneous when I insert the expression "BLOQUEADO" that in brazilian portuguese means Blocked. In abstract rather than insert a name of a eventualy cliente I fill the expression "BLOQUEADO" how I had proceeded for long years without impedition.
- Eventual client other Bloqueado.pdf
- (99.24 KiB) Downloaded 185 times
Which calendar do these events belong to, and which account does that calendar belong to?
