The reminder icon disappears from the notification area
Hello!
The reminder icon disappears from the notification area.
I haven't figured out yet what events will precede it.
There are times when it comes back on its own, but if I edit some post, or a reminder, than coming back, but later (after some hours or one day) it disappears again.
My phone is:
AEPIM v6.0.11
Andoid 9, Build 55.0.A.10.26
Sony Xperia 1
Thank you.
My phone is:
AEPIM v6.0.11
Sony Xperia 1
Thank you.
Re: The reminder icon disappears from the notification area
We're not sure how to reproduce the problem unfortunately. Maybe you happen to notice some specific actions that could be triggering it?
I'm working on the phone and a few minutes ago it even indicated seven reminders, and then the next time I look, the icon is no longer there.
I don't know what will happen.
Last time I closed the display, then after a minute I opened it again and then the icon was no longer in the notification area.
In AEPIM, on the other hand, if I work on something, especially if I edit a task, it appears again, and the messages and reminders are also there.
Unfortunately, I can't even say how long this might last.
I'm afraid that I won't receive some kind of notification.
Whatever experience I have, I will report it here on the forum.
Thank you.
Thank you.
I managed to film the disappearance of the icon (one such occasion) from the notification area.
https://ddlp7.data.hu/get/d4387d7bc3a3d ... 203902.mp4
This also happens when changing the language of the user interface, directly when the application switches to the specified language.
Thank you.
Thank you.
Thanks for sharing the video. It appears that you clear AEPIM from the memory (by swiping it up), and therefore the app stops showing notifications.
Hello!
When editing a task or creating a new task, the disappeared notifications will reappear.
It seems that only in such a case.
If I don't edit anything, it stays that way.
Where am I going wrong?
What can I do?
My phone is:
AEPIM v6.0.14
Sony Xperia 1
Thank you.
What can I do?
My phone is:
AEPIM v6.0.14
Sony Xperia 1
Thank you.
We would not recommend swiping up on the app to clear your memory. It is advisable to let the app stay in the background instead. Clearing the memory by swiping up may disrupt the app's functionality and potentially cause issues. It is generally better to allow the app to remain in the background, as this enables smoother multitasking and quicker access to the app when needed.
Thank you for the information and suggestion.
I very rarely swiping up applications.
And AEPIM almost never.
(I tend to close them differently.)
The disappearance of the icon is independent of the pull-up.
It also currently occurs in version 6.0.16.
But this has only been around for a few versions, it wasn't there before.
Unfortunately, I don't know exactly which version it started with.
By the fact that the icon disappears or does not appear, it indicates that there is we have no due date or task.
While there is, and even more than that, and we don't get to know about it.
This phenomenon or bug, although it may be small, but one of the main functions of the application is to know that we have something to do (and when).
However, it disappears like this.
May I request you to record another video demonstrating the problem, but this time without clearing the memory? Thanks!
https://data.hu/get/13958289/When_start ... cation.mp4
Direct link: https://ddlp8.data.hu/get/4476ef0269e4b ... cation.mp4
https://data.hu/get/13958290/When_chang ... ttings.mp4
Direct link: https://ddlp8.data.hu/get/4476ef0269e4b ... ttings.mp4
(I don't know which one does not involve without clearing the memory.)
I'm not sure if these are the only ones causing it.
There are times when I unlock the display and the icon does not appear, but it is impossible to know how long it has been like this and what caused it then.
Thank you.
Thank you.
What should these videos show us? Unfortunately, I don't see any issues in them. Thank you.
As you requested ("May I request you to record another video demonstrating the problem, but this time without clearing the memory? Thanks!"), in the two videos you can see the operation (when) the EPIM icon disappears from the notification area.
At the very beginning of the "When_starting_the_application" recording, the EPIM icon is still visible in the notification area, but as soon as the application starts, the icon disappears.
In the "When_changing_the_language_in_settings" recording, I accidentally selected the Italian language in the language setting and the icon disappeared from the notification area.
"When_starting_the_application" recording - Unfortunately, we're unable to reproduce the problem on our side. Does it occur each time you start EPIM?
The second video "When_changing_the_language_in_settings" doesn't seem to be available anymore.
Not always.
I tried a couple of times and it seems to occur when clearing the memory.
I checked both links of the "When_changing_the_language_in_settings" video and it still works.
Please try again! Thank you.
Sorry for the inconvenience!
Thank you.
Thank you.
Please refrain from clearing the memory, as we have already discussed this in previous posts.I tried a couple of times and it seems to occur when clearing the memory.
Will check it out, thanks.I checked both links of the "When_changing_the_language_in_settings" video and it still works.
