How can I insert only the 'date'?
DD1
Been thanked: 5 times
Post by DD1 »
When I use the shortcut, only the time is inserted in notes/tasks etc. I would like to insert only the date (with no time stamp), but can't find a way to get that done. Thank you.
Re: How can I insert only the 'date'?
In the Notes module, click on the "Insert Date and Time" button on the toolbar, then choose the desired format for insertion when using the shortcut. The selected format will be applied from now on.
DD1
Post by DD1 »
The menu is greyed out and won't allow me to change it.
VictorParkerPIM
Has thanked: 9 times
Been thanked: 70 times
Post by VictorParkerPIM »
When you go to a note in the tree bar, the Icons are not grayed out in the toolbar, they should be grayed until the focus is in the Note.
DD1
Post by DD1 »
Perfect! Thank you.
VictorParkerPIM
Glad it helped.
