Shortcut Key for read only does not work correctly.
- VictorParkerPIM
- Has thanked: 9 times
- Been thanked: 70 times
When I make a note Read Only with the shortcut key, it works when the Note Name is selected.
If focus is in the note the shortcut does not work for the note I'm in, but it makes the task Name read only that was last used.
Re: Shortcut Key for read only does not work correctly.
Thank you for bringing this issue to our attention. We will make sure to address it in the next update of EPIM. Your feedback is greatly appreciated!
- VictorParkerPIM
Thanks for the quick reply.
The Epim program is getting so good it is very hard to find something wrong with it.
- VictorParkerPIM
The (shortcut) for read-only still does not work in 11.7.4 for, mainly for Leafs and it still activates read-only in last used Task (Name).admin wrote: Sun Nov 19, 2023 4:48 pm Thank you for bringing this issue to our attention. We will make sure to address it in the next update of EPIM. Your feedback is greatly appreciated!
When there are several Leafs in a Note, you can select the Leafs that you want to be read-only with the pop-up menu.
With the shortcut key it's all or none.
Hopefully it will be fixed in the ver.11.8, waiting until the final release.
This is by design, the shortcut is used to make the whole note read-only.
- VictorParkerPIM
Thanks, I thought both methods would work the same.
- VictorParkerPIM
Thanks, the problem is fixed in ver.11.8 RC1VictorParkerPIM wrote: Wed Nov 29, 2023 11:57 pmThe (shortcut) for read-only still does not work in 11.7.4 for, mainly for Leafs and it still activates read-only in last used Task (Name).admin wrote: Sun Nov 19, 2023 4:48 pm Thank you for bringing this issue to our attention. We will make sure to address it in the next update of EPIM. Your feedback is greatly appreciated!
